Posted by Smith1000 on June 18, 2012 at 19:09:13 from (199.192.211.49):
In Reply to: Super C won't start posted by Smith1000 on June 17, 2012 at 15:57:28:
Thanks for the information. I tried to turn the rotor by hand and it would not turn. It feels like the teeth are engaged. I then turned the engine over again and the rotor did not spin. I pressed on the rotor when turning it over and it engaged and began to spin, but would not continue to spin. It would release and stop. As I turned it over, I operated the hydraulic lift and it seems to work fine. Haven"t checked the compression yet.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
