Re: Super C won't start
Posted by Jim Becker on June 18, 2012 at 19:50:54 from (173.74.120.222):
In Reply to: Super C won't start posted by Karl in MD on June 17, 2012 at 15:57:28:
99.44% chance your trouble is in the distributor. Don't waste your time looking elsewhere. Do what I said in my first post. No matter where the problem is, you're going to have to pull the distributor to fix it anyway.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
