It makes the noise idling in nuetral with the clutch engaged. Disengaging the clutch ( pushing down the pedal) stops the noise. It may (probably ) make noise in gear but there are so many other noises it is hard to distinguish.
Look for a grease seal that is leaking on the front of the transmission. Check that bearing. If that is just a bad seal, check the pilot bearing on the transmission input shaft.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
