Re: FARMALL H SPIN ON FILTER??
Posted by Phil Auten (TX) on September 29, 2000 at 05:53:27 from (206.175.72.226):
In Reply to: FARMALL H SPIN ON FILTER?? posted by LOU on September 28, 2000 at 05:47:18:
Lou,
Be sure there is only one gasket in the groove. Sometimes the old gaskets are VERY hard and become difficult to remove. This leads to small leaks.
Also, the bolt that holds the cannister cover on must be straight. The seal can leak with only a slight bend in the bolt.
Hope this helps,
Phil
Post A Followup
: Re: Re: FARMALL H SPIN ON FILTER??
