Re: no. 25 mower
Posted by SadFarmall on June 19, 2012 at 00:41:28 from (112.213.172.249):
In Reply to: no. 25 mower posted by Jeff A in TN on June 08, 2012 at 18:26:53:
I have a GL-25-VO, which is almost identical to the 25V. We had the lever arrangement, which is very good for giving the elbow a good hard crack! My grandfather fitted a two-way hydraulic cylinder, which made it far easier to use. You just time operation correctly and the cutter bar lifts just as it reaches the end of a row. The same for starting a row. The two-way cylinder makes sure that the cutter bar lifts and lowers at the same speed.
SadFarmall
