Posted by D Slater on June 19, 2012 at 07:36:08 from (184.15.43.82):
In Reply to: Re: governer? posted by farmall h 1939 on June 19, 2012 at 05:21:14:
Pictures of IH and power gov. H and one M power gov tube and small levers. H and M governor upper housings. IH and H P.G. and M linkage.
All power governors are not alike but you probably have something like the pictures. Depends how much work you want to do. If you don't have the power governor tube and shaft to the carb. Little lever from the end of the M tube needs put on the H tube. Sometimes shortening the tube and shaft is needed to line up and sometimes a new pin hole drilled. Need H upper housing put on the M housing. Need shorter threaded rod to go between the heim joints. Need governor drive gear changed. Power governor rear weight shaft bushing is made for a smaller diameter shaft on some so the power gov. shaft needs to stay with its housing if so.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
