Re: IH 300 Carburetor Questions
Posted by rustyfarmall on June 19, 2012 at 09:11:53 from (67.55.162.174):
In Reply to: IH 300 Carburetor Questions posted by ATF-110 on June 19, 2012 at 07:59:54:
You are better off not trying to remove that idle metering jet. You will only succeed in twisting the ears off the scredriver slot, or even worse, twisting the whole thing off and leaving only the remnants still screwed into the hole, and then it would need to be drilled out, and the hole re-threaded.
If that idle metering jet is intact, and not damaged, you need only make sure it is clean inside.
