Re: Another coolent flush question....
Posted by old on June 19, 2012 at 11:32:57 from (209.86.226.32):
In Reply to: Another coolent flush question.... posted by BigTone on June 19, 2012 at 11:20:12:
Pull the block drain plug and then rig up a fitting so you can hook a garden hose to the block drain and let it flow for say 2 hours. Have the radiator cap off so it has some place to go. That way your back flushing the system or in other words making it flow back wards of what it does when running so it cleans it out real good. Then pull that hose and let the block drain and that will get at least 3/4 of the water out. Pour in 1 gal. antifreeze full strength then top off with a 50/50 mix and your good to go
