Re: What row spacing do you use for 2-row cultivators?
Posted by gene bender on June 19, 2012 at 12:24:44 from (67.55.226.59):
In Reply to: What row spacing do you use for 2-row cultivators? posted by C. Amick on June 19, 2012 at 09:30:21:
By setting the front row shanks you can set the off-set to go down to 32. You just need to do the inside ones take the one off the left and put it on the right and the right one on the left then set the gangs for clearence. Ive done 30 with the B so you should be able to do the same with the C. You will need to change the shovels also.
