Re: 656d ampp light stays on
Posted by Owen Aaland on June 19, 2012 at 14:51:21 from (216.47.35.176):
In Reply to: 656d ampp light stays on posted by d beatty on June 19, 2012 at 07:40:30:
Most likely cause is a problem in the relay circuit, shown by the dashed line. The relay is what turns off the light. With the alternator running you should have about half the battery output terminal voltage on the R terminal. Check for the same voltage at the #2 regulator terminal. If you get the voltage at the regulator then either the relay in the regulator is not closing or the contacts are dirty.
third party image
