I brazed several pinhole leaks in an H oil pan, from the inside. Worked fine and was about a 15 minute job. I let it cool and filled it with water to check for leaks.
Pan was not leaking till I cleaned about 2" of sludge out of it, cleaned it up and painted. I found the leaks after reinstallation and had a slow oil drip. I now water test, the few I have cleaned out since, before I paint. I minor lesson from the school of HK
I've brazed multiple oil bath air cleaner cups from the inside and had great luck with those.
I'm real spooky about gas leaks and would try to find a replacement rather than repair. I'd be worrying all the time about it failing in another spot and starting a fire.
If you brazed it from the outside and epoxy lined it might make sense if you just can't find a good replacement.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
