Re: How do you tighten up these areas in the steering?
Posted by Wardner on June 19, 2012 at 20:15:31 from (4.154.230.74):
In Reply to: How do you tighten up these areas in the steering? posted by sflem849 on June 19, 2012 at 19:38:20:
Don't know what you have for reamers but you could measure the bores with a digital caliper and find something reasonable on eBay. While you are there, get some brass bushings. Go to a long established spring shop and get some hardened pins that you can modify. Those pins will be drilled for grease fittings. Maybe get the bushings too.
You will have to determine all the measurements but you should start with the pins and work from there.
Or you could remove the Pitman arm, drag link, tie rod, and lever and give them to machinist. He will figure it out and do the work. A spring guy might work as well but it seems like most are into BFH's and torches. Not much precision or care with those guys.
