The draglink and the block that connects it to the lever/arm off the steering box seem to be the two worst areas.
I wasn't sure if you could use a standard bushing on the steering. I will probably end up taking it to a machine shop. I do not have my mill set up yet and I need to learn how to use it first. The second part I am not afraid of, but it takes time and patience.
I have a line on a couple draglinks because mine is kind of trashed. Hopefully those pan out and then are not as worn out as this one.
Today's Featured Article - The Engine Rebuild Kit - by Curtis Von Fange. I always liked engine rebuild kits. They have all the replacement parts for overhauling an engine without going to the store to get gaskets, special measuring tools, or miscellaneous parts. They come neatly packaged, clean and tidy. But it's important not to let that packaging lull you into a false sense of security. The appearance of matching sleeves, pistons, rings, and bearings can cause frustration and agony if not properly measured and installed in a workshop environment. Following c
... [Read Article]
Latest Ad:
[More Ads]
