Re: Farmall Super A Oil barfing out intake
Posted by JRSutton on June 20, 2012 at 04:41:11 from (75.130.109.233):
In Reply to: Re: Farmall Super A Oil barfing out intake posted by ccaissie on June 20, 2012 at 04:31:47:
Did you check the valve lash? I don't think that was mentioned - and should definitely be tried first.
The valves may not be able to close.
As for the oil - I'd still suspect a head gasket - but it's possible when towing it it's drawing oil in around the valve stems and blowing that out the valves that aren't able to close.
Vacuum is a lot stronger at lower rpms - though - if valves aren't closed should be very low...
Either way - nothing should be blowing out the carb - fix that first and see what happens.
