Posted by The tractor vet on June 20, 2012 at 06:42:40 from (76.212.225.132):
In Reply to: Torque amplifier posted by Bill in IL on June 20, 2012 at 06:02:51:
The big thing about doing one is safety . Having a set of splitting stands good blocking and a cherry picker, and floor jack. If all you are doing is removing and replacing as a unit the hard part is getting the ft. seal installed properly and getting the unit thru that seal with out rolling the lip and once that is done getting the big nut tight and locked in place. Now if you want adventure and you want to rebuild it yourself this is where the fun begins and here ya got to read the book and the I T manual will do . the cause for the low side to be out is that the ramp and rollers are shot and the surface of the carrier is chewed up . Myself i would get a rebuilt unit and stuff it in . Now as to should i buy the HD one or the std. one , thats up to you as for me the std one will do just fine since i doubt that your going to be plowing 100 aces a year for the next fifteen or twenty years with it.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
