Re: Torque amplifier
Posted by Andrew Z on June 20, 2012 at 07:09:15 from (64.252.146.234):
In Reply to: Torque amplifier posted by Bill in IL on June 20, 2012 at 06:02:51:
Agree 100% with Vet, As far as safety its a heavy critter and second replacing the unit as a whole, i went though the same questions a few years ago with my 450... Get the whole unit and replace. As for the heavy or standard duty, I talked to "Lemans" (sp)in PA. And he said its more about the way you use it, that is properly and not use it as a break etc. I ended up with the standard duty considering the same unit is used in the 660 a 85 + hp 6 cly high speed engine.
I have some engine work done to my 450 currently in the 70-75 hp range, and the TA works great and thats pulling in 10,000lbs classes etc.
Also make sure you replace the dry TA clutch in front of the TA new pressure plate and disk, Also replace the main engine clutch while your in there as well.
Andrew
