Re: Farmall H hard starting
Posted by old on June 20, 2012 at 10:17:31 from (209.86.226.19):
In Reply to: Farmall H hard starting posted by Bzet on June 20, 2012 at 09:59:34:
An engine needs 3 things to run. Compression spark and fuel all at the correct time. You need a good blue/white spark that will jump a 1/4 inch gap or more. Points should be set at 0.020 and check that at all four lobe in the distributor. Pull the air cleaner tube off and try holding your hand over the air intake. You should get a good suction there and your hand should get covered with fuel. If you do not get both then you have a fuel/compression problem. Low suction compression problem no gas on you hand a carb problem
