Re: Farmall H hard starting
Posted by JRSutton on June 20, 2012 at 11:47:37 from (75.130.109.233):
In Reply to: Re: Farmall H hard starting posted by Nebraska Cowman on June 20, 2012 at 10:17:38:
Sounds like a good guess to me.
I'd check all your battery connections, especially the ground connection on the tractor side.
Even if it doesn't fix the problem, it's never a waste of time to make sure they're all clean and solid.
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
