Bolster steering shaft 350
Posted by Tom/Idaho on June 20, 2012 at 12:55:47 from (216.57.174.229):
I have the upper bushing ordered ($50.00) from the dealer, also the oil seal ($15.00). The seal looks (due to it"s location) rather difficult to get in place without damage. I think I will just drill and tap the bolster for a grease zerk like the bottom bushing has. The steering worm gear has had grease for a long time which is probably what wore out the bushing. At least this way the bushing will be lubed and I don"t have to worry about oil leaking past a damaged seal.Does anyone see a problem with that? The thrust bearing and lower bushing appear to be good and tight.
Thanks, Tom/Idaho
