Re: H Wiring
Posted by eye4iron on June 20, 2012 at 13:30:35 from (199.38.133.55):
In Reply to: Re: H Wiring posted by Bob M on June 20, 2012 at 07:35:26:
If your points were open there will be no drain shown on the amp meter when the switch is pulled out.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
