Re: 350 rear chassis ?
Posted by D Slater on June 20, 2012 at 14:10:26 from (184.15.43.82):
In Reply to: Re: 350 rear chassis ? posted by riverbend on June 20, 2012 at 10:28:53:
Housing shouldn't make a difference. Could be a problem with the linkage or release shaft if some parts were mixed with a 300. Is this a farmall or utility.
Pretty sure you have something wrong with the T/A clutch though. You say the springs are completly compressed, or is the fingers all the way in. With a cleaned up and good shape clutch carrier it pays to check the clutch before installing. With the carrier out of the tractor, new clutch plate and the parts bolted in carrier and on a flat surface the fingers should measure near 3.75 from flat surface to finger tips. Hey left a 3 out, adjust finger height to 3.375.
This post was edited by D Slater at 21:17:29 06/20/12.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
