The clutch release bearing is probably dragging and causing the transmission shaft to continue turrning after the clutch is disengaged. If there is a place to lube it, give it a couple shots of grease. I think the lube point would be through the hand hole on the bottom of the clutch housing. Beyond that, you can wait a few seconds after you disengage the clutch for things to stop or you can move the shift lever to the reverse side of neutral and press the lever forward (there is no gear there). Doing this will put some pressure on the transmission and help to stop the gears from rotating and then you can shift into gear without grinding.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
