Re: H foaming radiator
Posted by ltf in nc on September 29, 2000 at 09:21:25 from (206.228.214.217):
In Reply to: H foaming radiator posted by Mike T on September 29, 2000 at 06:50:53:
To determine if the head gasket is blown do the following. Fill the radiator, leave cap off. Get an old plug, break out the porcelain and weld an air line fitting to the plug base. Remove the plugs one at a time and install the modified fitting and apply 100 PSI of air and watch the radiator for bubbles. If the bubbles occur the gasket is blown or the head is cracked. Post your results. Good luck
Post A Followup
: Re: Re: H foaming radiator
