Re: Tractor Vet - Mounted Corn Picker II
Posted by The tractor vet on June 20, 2012 at 17:50:19 from (76.212.225.132):
In Reply to: Re: Tractor Vet - Mounted Corn Picker II posted by Kirk Affeldt on June 20, 2012 at 17:29:33:
Yes all you need is the axle mounting brackets that go on the axle and mount to the subframe and on 706's it uses TWo U /Bolts , where as the brackets for the 656 is the same as the M on up thru the 560's
