Re: Distributor and resistor questions
Posted by Bob M on June 20, 2012 at 18:45:23 from (69.207.87.163):
In Reply to: Distributor and resistor questions posted by Zachary Hoyt on June 20, 2012 at 18:23:41:
Zach - If the points are not making contact and grounding when closed, the voltage readings you observed are normal.
To verify try running a temporary jumper from the distributor primary terminal to a good ground. Now turn on the ignition and take your voltage readings again. You should see 12 volts on the ign side of the resistor; approx 5 - 7 volts on the coil side of the resistor and the resistor side of coil primary; and 0 volts on the distributor side of the coil primary. (Don't leave the ignition "on" longer than necessary to take voltage readings - to avoid overheating the coil and resistor).
I'd recommend replacing the points/condenser and see what you get.
Incidentally if your tractor is negative ground, the coil + SHOULD be wired to the resistor and the coil - to the distributor. However the coil will work fine with the connections reversed.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
