Re: H Starter Hang Up
Posted by pete 23 on June 20, 2012 at 19:24:31 from (74.32.238.2):
In Reply to: H Starter Hang Up posted by AL Moyer on June 20, 2012 at 11:07:59:
Tell you something else that can cause problems. When you push the starter button, do it firmly. I have seen more than one stick when in good shape just because the button was not firmly pushed. Will stick for one operator and never bother with a different one.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
