I would flow rate the pump. If that is not a possibility, you might just slip in a higher pressure relief valve from a newer tractor. You could go from 1600 psi to 2200 psi. With a small cyl diameter that may be your problem. Relief valve is located in seat support, right side, has 1 1/8 in hex head, about 3 inches long with screen in inside end.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
