Re: Torque amplifier
Posted by mkirsch on June 21, 2012 at 03:54:01 from (67.253.161.186):
In Reply to: Torque amplifier posted by Bill in IL on June 20, 2012 at 06:02:51:
The TA clutch is what gives you direct drive. If that is out, the tractor would drive around in TA all the time. You can tell because the tractor will freewheel down hills.
If the low side is out AND the TA clutch is out, the tractor is dead in the water. It won't move at all.
As for standard vs. heavy-duty, keep in mind that these tractors had standard TAs from the factory, and were used hard every day. A lot of these "bad" TAs are the originals, or 2nd, and the tractors are up to 60 years old. You'll never wear another TA out in your lifetime, standard or HD.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
