If you get a pressure gage and screw it in the end of the coupler, and plug it in then pull your lever you will get your pressure reading on both. The relief valve and what the pump can do. If you only get like 1200PSI the pump is suspect if you get upwards of 1600to 2200 your pump is probably good and your tripping the relief So you will know it is ok.This will leave flow as the last issue this can be checked if need be by using a flow meter or you can run into a pail as some body pours more oil in to the trans.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
