Re: Quick IH756 Hydraulic help
Posted by RPM1941 on June 21, 2012 at 07:32:43 from (173.23.76.185):
In Reply to: Quick IH756 Hydraulic help posted by nw_bearcat on June 20, 2012 at 19:30:47:
You might try different tips and/or couplers, they wont flow the oil, this was always a problem on heavy loads or too small cylinders. They must be compatable with each other, many different types out there, test with just pushing tips against each other, if one ball is stronger that could be problem. Also you can increase system relief hi pressure by swapping cartridge in side of seat with a another, they are made 1750/2000/2250/2500psi, would try 2250 first. IH/CNH part 396729R91.
