The resistor only "resists" when current is flowing. With no current flowing your readings are normal. Think of current as water flowing and the voltage as pressure. With no water flowing, pressure can build up even through a small restriction.
The battery + should be hooked to the coil + and the - on the coil to the distributor. Grab the end of the distributor where the rotor goes and push/pull on it to see how much play there is. Occasionally you find one with so much play that it defies setting a usable points gap. Should still generate a spark at some point.
Frankly I would just leave off the resistor in this case. It's a little harder on the points but you will get more fire and helps engines with weak compression, oil burning etc.
Hook it up without the resistor for your testing and you can incorporate it later when you do re-wiring.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
