Re: Farmall 300 PTO problem?
Posted by Zachary Hoyt on June 21, 2012 at 09:04:51 from (173.84.185.1):
In Reply to: Re: Farmall 300 PTO problem? posted by D Slater on June 21, 2012 at 07:17:57:
Thanks, that makes sense. I will check on the play in the shaft as you described. I'll split the tractor and that way I can keep twiddling with the engine and also see what needs to be replaced in the clutch area and check on the TA. I took the top cover off and the TA turns easily one way but not the other, so that makes me think the the sprague clutch is working. The TA is in low currently but the lever is broken off and it can't be shifted.
Zach
