Re: IH farmall W-4 super hub
Posted by Brian AB on June 21, 2012 at 09:32:09 from (173.210.227.229):
In Reply to: IH farmall W-4 super hub posted by mrpete on June 20, 2012 at 20:11:54:
I had the same problem with a W-4 last year. One hub came off easily, the other was frozen on. I made up a puller of 3/4"threaded rod and a piece of 3" square tubing 5/16" wall. It took a month of using a 3/4" impact every couple of days to keep it tight as well as soaking it regularly with ATF/acetone. Every time I tightened the bolts I would hit it a couple of times with a sledge.
I had to pull the axles to press out the spacers so I could replace the seals.
Today's Featured Article - Dad's 1945 Farmall A - by Bobby Duke Jr.. I am writing about my Dad's 1945 Farmall A. The tractor was purchased in 1945 by his father, Mr. Davis Duke. It was used to farm tobacco from 1945 to 1963 by my grandfather and by my father. ... [Read Article]
