Re: Super H with bad 5th gear
Posted by wisbaker on June 21, 2012 at 10:51:49 from (207.118.159.235):
In Reply to: Super H with bad 5th gear posted by AL Moyer on June 21, 2012 at 10:20:49:
I can understand, those old H's and I assume Super H's were a little over geared or under motored to be starting out in 5th gear like you should. So the procedure became get her rolling in 4th and put the clutch in and try to mash'er into 5th before it stopped rolling 'cause you needed that little but of rolling to get it rolling down the road if you had much of a load behind you like a full hay wagon or full manure spreader.
