Re: Brakes M Farmall Change from disc to band type
Posted by Janicholson on June 21, 2012 at 11:23:18 from (96.24.99.126):
In Reply to: Brakes M Farmall Change from disc to band type posted by Lyle Anderes on June 21, 2012 at 11:05:50:
The differential bearing carrier (where the shafts come out)is not removable without removing the rear axles and bull gears. If the disk brake system has an adapter bolted to and splined onto the pinion shaft, to make it stick out, and if that can be removed, then that is what is needed. There should be a bolt and gasketed washer holding the brake drum onto the stub shaft in that carrier. Jim
