Re: Brakes M Farmall Change from disc to band type
Posted by D Slater on June 21, 2012 at 11:25:36 from (184.15.43.82):
In Reply to: Brakes M Farmall Change from disc to band type posted by Lyle Anderes on June 21, 2012 at 11:05:50:
The 29 spline part should slide off the regular IH shaft, Unless its stuck or rusted. The inside shaft of the splined sleeve is a regular M splined shaft. Bearing cage is regular IH and can,t be completly removed from the transmission housing without moving the bull gears out of the way inside the gear housing. Like Jim said there's a bolt in the shaft end. I just thought you already removed it. Also plate the inside brake disc contacted needs unbolted and removed before installing the band brakes. Put the parts tractor bolts back in the housings.
This post was edited by D Slater at 13:03:20 06/21/12.
