Re: 1947 Farmall Internation H tractor with scoop
Posted by old on June 21, 2012 at 12:09:18 from (209.86.226.34):
In Reply to: 1947 Farmall Internation H tractor with scoop posted by Rob BT on June 21, 2012 at 12:00:03:
Check all battery connection cables starter etc. You can also have a jammed starter bendex so you may need to loose n the starter to pop it free. Your starter or starter switch may also be bad. Many things can stop the starter from spinning the engine over so it will start so you need to check all connections and make sure they are clean tight and bright. If you do get it to spin over but still not start make sure your getting a good blue white spark that jumps a 1/4 inch gap or more
