Re: Super H with bad 5th gear
Posted by Bob M on June 21, 2012 at 13:19:55 from (69.207.87.163):
In Reply to: Re: Super H with bad 5th gear posted by AL Moyer on June 21, 2012 at 10:51:44:
Al - "He said it just grinds...." is not a good omen(!)
You might get lucky and find it's simply a bent shift fork. However more likely the 4-5 input and sliding gears are ruined from abuse.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
