Re: 200, C/SC compatible?
Posted by Dennis K (WA) on June 21, 2012 at 13:21:01 from (24.21.78.195):
In Reply to: 200, C/SC compatible? posted by dgerth on June 21, 2012 at 05:42:17:
dgerth, here is a photo of the mounting holes on the trans/diff housing on my 1949 'C'. Casting code is 'S' which should be right for 1949.
Hope this helps.
Dennis
third party image
This post was edited by Dennis K (WA) at 13:40:30 06/21/12.
