Re: 1947 Farmall Internation H tractor with scoop
Posted by Buzzman72 on June 21, 2012 at 14:00:06 from (74.129.194.231):
In Reply to: 1947 Farmall Internation H tractor with scoop posted by Rob BT on June 21, 2012 at 12:00:03:
OK...dealing with a paper air filter makes me wonder what else may have been modified on this tractor.
Do you still have the hand crank? Have you tried to turn it with the hand crank, with the coil wire removed, to make sure the engine will turn over? If "the motor will not turn over," how do you KNOW you have compression?
And if the starter was "checked," I suppose that means it runs without an excessive amperage draw when it's off the tractor, and the starter drive is moving into the proper position as well.
How long ago was the tractor running, before it quit on you? A year? A month? A week? Yesterday?
Do you have full voltage to the coil? That is, have you taken a volt-ohm meter and checked for at least 6 volts going TO the coil?
Personally, I'd be awfully leery of turning the engine by the fan, if it will "try to start" that way; sounds to me like a good way to lose body parts if it does accidentally start.
From your description, I still DON'T know more about your problem than I DO know about it.
Today's Featured Article - A Question for Dads This recent topic from the Tractor Talk discussion board is being highlighted because it is an awesome display of the caliber of individuals that have made this site their own. The young person asking questions received positive feedback and advice from total strangers who "told it like it is" with the care many reserve for their own kids. The advice is timeless... so although it isn't necessarily antique tractor related, it will be prominently displayed in our archives to honor those who have the courage to ask and those who have the courage to respond in an honest, positive manner. ... [Read Article]
