Re: 1947 Farmall Internation H tractor with scoop
Posted by mkirsch on June 21, 2012 at 18:28:08 from (67.253.161.186):
In Reply to: 1947 Farmall Internation H tractor with scoop posted by Rob BT on June 21, 2012 at 12:00:03:
You can't trust the "test" that they do on the starter. I've never seen them get it right. All they do is apply power, and if it spins, it's "good."
You also can't trust visual inspection of the battery connections. Don't just look, do the preventative maintenance even if they "look good." Also if you've got one of those replacement ends that clamps on to the cable with two bolts and a flat strap, that's another connection that needs to be taken apart and cleaned.
