check out the picture on case ih website. there's a $15 gasket and 4 o rings you might as well replace while you're in there. the pump is bolted to that cover with a spacer in between. so you leave the 4 bolts in the middle, pull the whole thing out, then change out the pump.
from your original post it sounds like it will lift header all the way, just not fast enough. if you start with the header all the way down, does it start to lift faster, then slow down when it takes the weight off the ground? that might indicate a slightly worn pump, as leakage increases (and pump output decreases) with increased pressure. if not, it sounds like you've got a restriction somewhere.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
