1466 clutch adjustment
Posted by larryanderson on June 22, 2012 at 03:53:55 from (75.105.32.52):
If I remember correctly the 66 series have hydraulic clutches.Are they adjustable?I just got a low houred 1466 and it seems like you have to let the clutch pedal out quite aways before it engages.Also the 3 point will settle after an hour or so.Deal in 20 series JD where it can be common.Thanks
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
