Re: H rear wheel spacing
Posted by rustyfarmall on June 22, 2012 at 06:11:12 from (67.55.162.174):
In Reply to: H rear wheel spacing posted by BruceS. on June 22, 2012 at 03:56:58:
Move that swinging drawbar clear over to the left side as far as you can get it and do not use it. Hook the plow clevis to the center hole in the horseshoe drawbar. Your plow will pull a lot easier if it is hitched as close to the tractor as you can get it. The right rear tractor wheel needs to be slid all the way in on the axle. I repeat, do not use the swinging drawbar. It was never intended to be used for pulling a plow.
