Re: I split the 300 and this is what I found
Posted by Mike1972chev on June 22, 2012 at 11:23:42 from (75.149.81.173):
In Reply to: I split the 300 and this is what I found posted by Zachary Hoyt on June 22, 2012 at 10:45:26:
Are those concrete blocks sitting under the rear end????? GET THOSE OUT OF THERE!! Those can crumble apart in seconds!Get some solid timbers or something steel.
