Re: I split the 300 and this is what I found
Posted by Bouncer on June 22, 2012 at 15:17:56 from (68.28.138.229):
In Reply to: Re: I split the 300 and this is what I found posted by Zachary Hoyt on June 22, 2012 at 14:16:41:
When they stripped, the pressure plate shifted. I it caused the throw out bearing to eat into the fingers, and partially disengage the clutch enough for it to slip and build up all that glaze from heat. I am sure the noise happened at the same time and he had no idea what was going on.
