Re: I split the 300 and this is what I found
Posted by TJV on June 22, 2012 at 21:03:22 from (67.230.241.17):
In Reply to: I split the 300 and this is what I found posted by Zachary Hoyt on June 22, 2012 at 10:45:26:
as far as your question to the TA assenbly only turning one way that is correct the over running clutch in the ta will only allow it to turn one way if it turned both directions the tractor would not move when the ta was in low but turning only one way by hand still does not say the ta is good you cant put the pressure on it that the engine does. As other have recconended get a manual the I&T is a good one for ta instructions.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
