Re: Quick IH756 Hydraulic help
Posted by nw_bearcat on June 23, 2012 at 05:00:42 from (69.66.185.0):
In Reply to: Quick IH756 Hydraulic help posted by nw_bearcat on June 20, 2012 at 19:30:47:
Update with a pressure gauge plumbed into the pressure side of the lift circuit.
Running this morning with the gauge inline. Cool oil(77*) 1000rpm or 2000 rpm about 1300-1400psi while lifting and 1500psi at the end of the stroke.
After cutting 3-4 acres (oil hot) 1300-1400 lifting and 1500 end of stroke regardless of engine rpm. At no time did I see it top 1500psi.
I think we're going to start with a 886 relief valve and see if that lets us boost the pressure up some.
