Posted by Janicholson on June 23, 2012 at 07:30:44 from (96.24.99.126):
In Reply to: H ampmeter jumping posted by j hakenwerth on June 23, 2012 at 05:55:40:
Mechanical voltage regulators are electrically noisy. They produce variations involtage output that ---average--- the desired charge voltage and current. from a millisecond to millisecond view, they produce voltage from below bat voltage, to twice the bat voltage. Batteries and lights do not care as long as that average is ok on a second to second basis. Amp meters of best design use a resenous liquid on one of the pivots for the needle. This sticky viscous material dampens the needle fluctuation and produces the steady needle showing an average charge rate. (This is not the only method, but common) The electronic controls of newer equipment and cars (if equipped with a gauge) would need much less dampening if any. Original meters can and do have this material dry out and stop working, new less expensive meters don"t even have it. Thus your viewing the needle jumping around might be irrelevant but distracting. Swinging through full scale side to side is an indication of connection problems, or generator/VR issues. Jim
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
