Re: spun bearing
Posted by Mlkgsmer on June 23, 2012 at 10:12:35 from (174.232.16.76):
In Reply to: spun bearing posted by blunted on June 23, 2012 at 08:19:09:
Depending on how loose, loctite makes a procuct called stud and bearing mount. If a little thicker "glue" is what you need caterpillar sells a high strenghth retaining compound that also works awesome. I use both sepending on circumstances at work.
